Hello, I am going to crossfire my 7870 with a r9 270x. My power supply only has 2 6/8 pin connects on it. It's 600w I went on cooler Master power supply calculater and it will be enough to power. But what should I adapt to 6 pin? Should I get a 6 splitter? Or 2 melex to 6 pin?
Thanks,
https://linustechtips.com/topic/792227-6-pin-splitter/
doesnt crossfire require two identical cards?
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/792227-6-pin-splitter/#findComment-9977854
3 minutes ago, derFensterputzer said:
Nope, AMD isn't as restrictive as Nvidia
wait could you crossfire a rx 580 and a 5770
My Stuff n' Things
https://linustechtips.com/topic/792227-6-pin-splitter/#findComment-9977879
No. They have to be based off of the same GPU. You can crossfire an RX 470, 480, 570 and 580, with them all tuning themselves down to match the 470, because they all use the same chip.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/792227-6-pin-splitter/#findComment-9977899
Theoretically yes. The problem about it is, that the VRAM of the RX580 will be reduced to the 1GB of the 5770.
So I wouldn't suggest you to do that.
However pairing a R9 270X with a HD 7870 would be completely fine since both have 2GB VRAM
https://linustechtips.com/topic/792227-6-pin-splitter/#findComment-9977908
No, you cannot crossfire two different GPUs. See my explanation above this.
USEFUL LINKS:
https://linustechtips.com/topic/792227-6-pin-splitter/#findComment-9977916
Thanks,
sorry we got off track. I would use molex
My Stuff n' Things
https://linustechtips.com/topic/792227-6-pin-splitter/#findComment-9977922
I could have sworn I've seen benchmarks with crossfire between a rx480 and gtx 1070 once but can't find them anymore. It had interesting results generally out preforming either card in normal crossfire/sli by slight margins. But I can't find it so mayhaps it never happened. You probably know better than me anyway.
https://linustechtips.com/topic/792227-6-pin-splitter/#findComment-9977962
