That's a great build, good spread of money across the board so far. If you wanted to your power supply could be fine but I would recommend upgrading to something new and gold rated since your connect a 1080ti and ryzen 1700x to it. Case looks EPYC toooxD
Edit: I know your current supply is gold rated rn, but just grabbing a new one that has the same rating would be a great pick up.
If I had to choose between my computer and girlfriend, well lets just say you can play more games when single.:)
https://linustechtips.com/topic/792065-how-is-my-build/#findComment-9975906
15 minutes ago, Jonathan57344 said:
https://pcpartpicker.com/list/p6r6bj
I just switched to a new case. https://www.newegg.com/Product/Product.aspx?Item=N82E16811139078&cm_re=spec_alpha-_-11-139-078-_-Product
I'm thinking about using my current power supply, but it's now 4 years old. it's a EVGA NEX650G.
the NEX isn't that good but it'll power those components just fine.
just a few edits to save the price down.
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($299.44 @ OutletPC) just as good after overclocking.
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($107.99 @ Amazon)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($126.98 @ Newegg)
Memory: Team - T-Force / Night Hawk 16GB (2 x 8GB) DDR4-3200 Memory  ($124.99 @ Newegg)
Storage: Samsung - 960 EVO 250GB M.2-2280 Solid State Drive  ($127.99 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G  Video Card  ($683.99 @ SuperBiiz)
Total: $1471.38
Generated by PCPartPicker 2017-06-12 00:27 EDT-0400
https://linustechtips.com/topic/792065-how-is-my-build/#findComment-9975925
Eh, the NEX/G1 is rather lacklustre but it should suffice. I'd drop the R7 1700X down to a R7 1700 and overclock it.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/792065-how-is-my-build/#findComment-9975931
Looks pretty solid, just a few things.
  • If you intend to overclock, which I think it's fair to assume you are with that beefy AIO, you should get the 1700 instead of the 1700x. It saves a little bit of money and they overclock literally the same.
  • The NEX you already have is an okay power supply, it'll definitely power the components. Although it's not great quality and it's got some years to it so it wouldn't be a bad idea to upgrade it. Up to you. If you do get a new power supply, I would recommend a Corsair RMx or EVGA G2/G3/P2. 650w is perfect.
  • I wouldn't bother with a founder's edition graphics card. They run hot and loud. Get an aftermarket card.
Desktop - CPU: Ryzen 7 3700x | COOLER: be quiet! Dark Rock 3 | MOBO: ASRock X370 Killer SLI/ac | RAM: 32GB Corsair Vengeance LPX 3200MHz | GPU: MSI RTX 2070 Super Gaming X Trio | STORAGE: 2x XPG SX8200 Pro 1TB, Crucial MX300 525gb, Seagate Barracuda Pro 4TB | CASE: Phanteks P400s TG White | PSU: Corsair HX750i
Laptop - Dell XPS 13 | Intel i7 7500u | Intel HD 620 Graphics | 8GB RAM | 256GB M.2 SSD
Peripherals - KEYBOARD: KBD67 Lite w/Gateron Milky Yellow Pros | MOUSE: Razer Deathadder V2 | AUDIO: Sennheiser HD 6XX, Truthear Hexa | MONITOR: Dual 1440p 27" MSI Optix MAG274QRF-QD
https://linustechtips.com/topic/792065-how-is-my-build/#findComment-9976082
