Ok so i recently got a MacBook Air and the mic/ headphone combo jack for some reason can't record an external mic. Well, it's a quarter inch cable running through an adapter that can plug into the computer. So I was looking at a Sabrent USB External Stereo Sound Adapter. Would that solve my problem? Or would the Mac still not recognize it as a microphone?
https://linustechtips.com/topic/791655-help/
I delive there's a MIDI software utility on Mac you may need to configure, but IDK much about a mic on Mac, but it seems to work with the inline mic on headphones.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/791655-help/#findComment-9971281
Just now, freshprinceofbellpeppers said:
how would i do that
I don't really know, I've just opened it and been confused, then closed it. I'd bet Apple has a tutorial page for it somewhere, or there's a YouTube vid on it.
Mouse: EVGA X17
https://linustechtips.com/topic/791655-help/#findComment-9971290
But would it recognize it as a microphone? I'm trying to record my guitar into my mac and thats all I need
https://linustechtips.com/topic/791655-help/#findComment-9971292
Strange. Does it see it in GarageBand? Does the mic need an external power cable? It's wired it's not working, as Apple advertises peeps using MacBooks with GarageBand for this very thing.
Mouse: EVGA X17
https://linustechtips.com/topic/791655-help/#findComment-9971304
I haven't purchased the usb adapter yet. I just need to know that if i plug in a 3.5 mm mic into it if it would recognize it as a device
https://linustechtips.com/topic/791655-help/#findComment-9971307
Oh. You've tried an adapter for the headphone jack on the MacBook?
Mouse: EVGA X17
https://linustechtips.com/topic/791655-help/#findComment-9971315
Nope. I just need to know if like it would recognize it as a device or just ignore it. In theory it should, but idk if Apple has deliberately done something in the software to prevent it
https://linustechtips.com/topic/791655-help/#findComment-9971326
I don't see why not. It is the Audio out/Mic in combo port, so it should work. And if they disabled it, then they couldn't advertise people using the Mocs they sell one their own site for GarageBand. I'm 99% sure it'll work. Just get the adapter with Amazon Prime, and you can return it if it doesn't work.
Mouse: EVGA X17
https://linustechtips.com/topic/791655-help/#findComment-9971340
Alright. Thanks so much!
https://linustechtips.com/topic/791655-help/#findComment-9971342
