Hi everyone...
i'm new to watercooling and i have a question about normal temps during stress test...
my cpu is 6900k overclocked to 4.4 Gh and my gpu is 1080 ti FE overclocked to 1745...
my loop is cpu and gpu combined loop with one 360(ek xe 360) rad and one 280 rad(xspc ex280)...
the gpu temp is 50 at most stressful tests but the cpu is continously on 85 to 100 under stress with aida64 and prime 95...is this normal or sth is wrong with it?
https://linustechtips.com/topic/791557-normal-watercooled-temps/
that seems incredably high for watercooling, thats hot enough to boil your cooling water lol. how much voltage are you feeding that CPU?
Builds:
https://linustechtips.com/topic/791557-normal-watercooled-temps/#findComment-9970130
The voltage is 1.375,,,and the temp is for the cpu not the watercooling system itself
https://linustechtips.com/topic/791557-normal-watercooled-temps/#findComment-9970257
yah i know about the temp but its still really high. thats quite a high voltage you are running, if you can then try dropping it a bit seeing as 100C isnt really a good temp for the CPU
Builds:
https://linustechtips.com/topic/791557-normal-watercooled-temps/#findComment-9970262
Yeah its so high,,,the problem is that i dont know what is the normal temprature range for a watercooled cpu while overclocked stress test,,,do you have any information about this?
https://linustechtips.com/topic/791557-normal-watercooled-temps/#findComment-9970308
Well if for some reason you like to do stress testing, that's how high my 4790k sits.
https://linustechtips.com/topic/791557-normal-watercooled-temps/#findComment-9971019
60C tends to be about the max usiually, often bellow that and sometimes above it. what thermal paste are you using?
Builds:
https://linustechtips.com/topic/791557-normal-watercooled-temps/#findComment-9971741
The thermal paste is the one with ekwb waterblock,,,without overclock my stress test temp is good around 48 degree ,, but when overclocked to 4.4 on all cores it rises dramaticly to 90 to 100...one more thing is that this high temp is only when aida64 stress test is running,,,on other high load tasks like cinebench its on 70 to 80....
https://linustechtips.com/topic/791557-normal-watercooled-temps/#findComment-9974576
still a tad high but probably because you are running almost 1.4V
Builds:
https://linustechtips.com/topic/791557-normal-watercooled-temps/#findComment-9974610
Which pc case are you building in? I was using a Phanteks Evolve Enthoo with a top mounted radiator but it seems like the top cover was preventing the hot air from the rad from leaving properly so it was actually heating up the case pretty badly. Removing the top cover lowered temps by 10 degrees. Could be something similar with yours.
https://linustechtips.com/topic/791557-normal-watercooled-temps/#findComment-9976479
The heat output by the cpu ist the same weather it is cooled correctly or not. So no it would never boil the cooling liquid because there is not enough energy. The high temps indicate a bad heat transfare to the coolant. Meaning either thermal paste bad, or there are lage air bubble in the cpu block. remount the cooling block and try the shake out the bubbles
https://linustechtips.com/topic/791557-normal-watercooled-temps/#findComment-9976637
i simply noted that 100C is hot enough to boil water, it wont untill the coolant temp is 100C but that could happen in the block but yah probably bad transfer
Builds:
https://linustechtips.com/topic/791557-normal-watercooled-temps/#findComment-9976649
