I upgraded to 2 Asus GTX 1080 ROG Strix recently and I run them on SLI.
Since i have a 1440p 60 fps monitor, it's overkill for most of the games I'm playing - I'm planning to upgrade to the Asus PG279Q with 1440p and 165 Hz refresh rate but that won't happen until august.
If I am playing less demanding games, will it do any good to disable SLI for now?
Another to ask the question is:
If I have 1 GPU at 100% load vs 2 GPUs at 50% load .. which one consumes more power? I usually cap my frame rates at 60 anyway.
Mobo: ASUS X99-A  // CPU: i7-5820k // GPU: ASUS GTX 1080 ROG Strix //  Ram: 4 x 4 GB 2666 Mhz G.Skill Ripjaw // SSD: Samsung 960 Pro 512GB NVMe //  PSU: Cooler Master V850  // Case: Corsair 760T Arch White // Mouse: Logitec G903 Lightspeed // Keyboard: Logitech G Pro // Headphones: Audio Technica Ath-R70x // Monitor: BenQ BL2710PT
https://linustechtips.com/topic/791343-disable-sli-save-power/
could always enable 4k supersampling haha. Disabling SLI doesnt turn off one of the cards, just disables using them in tandem in games afaik. If you want to save power, unplug one
Main Rig:
| 13900K@6.1/4.7 w/TVB | Corsair h150i Elite LCD | Sapphire NITRO SE+ 6900XT@2710MHz | ASUS Z790 Strix-E | Corsair DDR5 Dominator Platinum 2x16GB@6200MT/s | Lian Li O11 Dynamic EVO |
My Folding Stats
https://linustechtips.com/topic/791343-disable-sli-save-power/#findComment-9967983
But if I only have 1 monitor and I turn off SLI, the 2nd GPU will be in idle no?
I don't want pull out the cards because the RGB effect lok great on my set-up :D
https://linustechtips.com/topic/791343-disable-sli-save-power/#findComment-9970857
