Compatibility problems?
Go to solution Solved by 3 Lions,
A Q6600 would run in that motherboard.
This may be of a very quick post, although, would such motherboard: http://www.ebay.co.uk/itm/HP-Compaq-531965-001-503363-000-536884-001-MicroTower-Socket-775-Motherboard-/282379142031?hash=item41bf1bc38f:g:H~MAAOSwfVpYtpve&autorefresh=true
Function with that of something like a Intel Q6600?]
Thank you very much in advance! My apologies if information has not been included.
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/790980-compatibility-problems/
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/790980-compatibility-problems/#findComment-9964205
2 minutes ago, EnergyEclipse said:
It will?
Yep it's an LGA 775 CPU and your motherboard only supports the LGA 775 socket.
زندگی از چراغ
https://linustechtips.com/topic/790980-compatibility-problems/#findComment-9964223
LGA 775 was really confusing.
First, you had the 900 Series chipsets for Pentium 4 and the original Core (Core Duo, Core Solo), and you couldn't update the BIOS to support Core 2
Then you have the 30/40 Series which only worked with Core 2
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/790980-compatibility-problems/#findComment-9964234
I agree, anything really lower than that and I get lost, so forums help a lot. Also I can't actually find the specific maximum RAM capacity of that board. I know its DDR3 but nothing other than hat currently.
https://linustechtips.com/topic/790980-compatibility-problems/#findComment-9964249
I found that its the Q43 series chipset, so it should work.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/790980-compatibility-problems/#findComment-9964257
