Hi all! I have a Thermaltake Versa H15 Micro ATX case, which I just did a new build in, and I'm looking to trick it out. The problem is, there are about eight billion different kinds of RGB lighting strips, and I have no idea which ones are good and which ones aren't. The lighting effects will be relatively subtle. They're just going to shine through the mesh in the front of the case, and I'm going to cut some designs into the side panel which I'd like to have light shining through. What are some good strips to look at? Any recommendations welcome!
EDIT: I'm very new at this. What connectors on the PSU will I need for rgb lights? I've got an eight pin, three SATA, and three molex connectors left.
Everything I know I learned from the internet. Also school.
Current Desktop:
CPU: Ryzen 5 1600 @3.65 ghz, Cryorig H7
MoBo: Asus Prime X470-Pro
GPU: Gigabyte RTX 2060 Super OC
RAM: 2x8 gb Corsair Vengeance LPX DDR4 @2666mhz
PSU: 650W EVGA SuperNova
Storage: 120gb SK Hynix SSD, 240gb SanDisk SSD Plus, 1 TB 2015 WD Blue
Case: Corsair Carbide 100R
Peripherals: Logitech G Pro keyboard, Razer DeathAdder Elite, Logitech G305, Logitech G600, 24" AOC FreeSync 1080p monitor x2
https://linustechtips.com/topic/790944-choosing-led-strips/
Mine use molex.
As for which ones you get is really up to you, read reviews and stuff of course but there isn't much difference in them, some use magnets to hang on and some use double sided tape.
Here are the ones I've been using for reference;
https://www.amazon.com/gp/product/B01AZ4XX0E/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
I've had them in 3 pc's and a fish tank for 2 years now. no issues.
Ryzen 9 3950x - 64 GB DDR4 - NVME 980 pro SSD - EVGA RTX 3080 FTW Ultra - FAD CASE
Full custom loop / links below out of date
LTT Build Log | PCPP Build Log
_____________________________________________________________________________________________
Sorry if I stop responding, I've probably gotten busy as I mostly am only on here while working.
https://linustechtips.com/topic/790944-choosing-led-strips/#findComment-9963717
You can try something like this:
https://cablemod.com/product/cablemod-widebeam-magnetic-rgb-led-kit-60cm/
It's powered via SATA and you can change the colors via the controller.
Build goes here :) :
CPU: Core i7-5960X                        Storage: 500GB Crucial MX200                      Case: Corsair 760T (White)
Mobo: ASUS X99 Deluxe II                             3TB Seagate Barracuda                   PSU: Corsair AX1200i
RAM: 32GB G.Skill TridentZ RGB                   6TB WD Red                                     Other stuff goes here :)
GPU: Nvidia TITAN X (Pascal)                         1.2TB Intel 750 series PCIe SSD      Other stuff goes here :)
https://linustechtips.com/topic/790944-choosing-led-strips/#findComment-9963721
@TraskJ If you want a truly vibrant LED solution, check out our CableMod WideBeam LED strips/kits. The strips can be powered via compatible motherboard headers, or you can purchase the kit to control them via SATA/DC power.
https://linustechtips.com/topic/790944-choosing-led-strips/#findComment-9963969
