Cpu temp's what's wrong?
Solved by PrimeSonic,
So you're using an AiO by Cryorig?
AiOs tend to have pretty stiff tubing. Something may have gotten loose in the move.
Cause there's no good reason for the temps to change that drastically just from changing the location of the radiator.
Check all the connections between the motherboard and the pump/fans.
And honestly, I would still try re-seating the block in case it got moved.
