Hitting Power Limit Early?
7 hours ago, Mike Soda said:Phew okay thank you, should I try running it again tomorrow? Is there a way I can prevent Defender from doing that again? How long should I test for at max?
Sorry so many questions
I just don't get the concern is all. If it benches on par (within a few points) with similar GPUs, if you don't encounter any massive hitching, or you're getting performance comparable to game bench framerates, there's nothing wrong with the card. Core frequency is never guaranteed, varies with every individual GPU and too high overclocks can result in performance instability with Pascal, not just crashes. Not to mention that you can monitor all your telemetry with an On Screen Display in real time with Afterburner, from voltage to power overall power usage. So if ever you encounter issues, you can troubleshoot like that. There's just nothing wrong with the card, you don't need to test any more. Just don't be overzealous with frequencies. Review samples are a very small percentage of the number of GPUs on the market, so don't always aim for those numbers.
