So I'm about to start my first build (a water-cooled one) and I was trying to see if all the parts worked before I put them in the case. So I assembled it all and when I turned on the power supply nothing happened. I have a corsair 750RMX and the cables are almost impossible to put in all the way. I was not able to push the motherboard cable all the way in. I did test the power supply with a paperclip and the fan did spin. I am getting some cablemod cables in tomorrow, but what can I do in case those have trouble too? Is there a problem with the supply?
https://linustechtips.com/topic/790707-power-supply-cable-troubles/
soundslike you dont have cpu power plugged in.
can we get a picture of everything all plugged in and we can tell you if you're missing anything obvious
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
Just now, coldice said:
I had 8 pin cpu, 24 pin, 2 pcie for graphics card, and an m.2 ssd
standoffs?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Do you have to put it on standoffs if you're testing it outside the case just to see that everything works?
1. please quote me for notification
2. cardboard box should do outside the case. if in the case use standoffs. otherwise use motherboard or other cardboard box.
Full Specs
Helios EVO (Main):
Delta - Laptop
I put the motherboard on the box
installed cooler?
Full Specs
Helios EVO (Main):
Delta - Laptop
Yes what does this have to do with the system not turning on. No fans would spin or anything on graphics card, cooler, and power supply. Also no lights lit up on my motherboard.
RMA
Full Specs
Helios EVO (Main):
Delta - Laptop
20 minutes ago, coldice said:
But the power supply would spin up with paper clip
As in mobo.
ALSO PLEASE QUOTE ME
Full Specs
Helios EVO (Main):
Delta - Laptop
29 minutes ago, JDE said:
RMA
Hold up there, there is more to check
Please post photos as recommended by @Tsuki showing what is connected and for the main connectors how far they have gone in. I suspect that the cables are not going in far enough for full contact. Had this happen with my flatmates PC. Pull the cables out and put them back it ensuring they went all the way in and worked fine
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
I will try this once I get my new cables.
