Hello Tech Tips Community I am in the process of ordering parts for my first build using pcpartpicker link here:
https://pcpartpicker.com/user/TerrellB/saved/B9wBmG
I had a couple questions as I really want save as much money as possible.
First off should I worry about buying a z170 board instead a b250 board to future proof my pc?
Is another 60 bucks on a 120 gb add worth it to add win 10 on it or is a 1tb hdd good enough for now?
Should I buy a cheaper case and spend that money elsewhere or just wait to buy a s340 case which I think is beautiful?
Praise all who respond and ty for reading!
https://linustechtips.com/topic/790353-my-first-build/
No need
1TB is enough if you don't store shitton of movies like I do. 120GB would be worth it imo. Improves game loading time and windows boot too
Yes you should, case at most improves thermals, but it's not noticeable. You won't get instant load time or free FPS because of beautiful case.
https://linustechtips.com/topic/790353-my-first-build/#findComment-9956815
get 1 8gb stick instead of 2 4gb so you can upgrade to 16 later on
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/790353-my-first-build/#findComment-9956857
Agreed. 1x8 gig might be a little more expensive (by like two dollars) but it's worth it for future expandability.
Hold up, I just reread your part list. There's not much point to upgrading that RAM with that processor. 2x4 will give you slightly (VERY slight) better performance.
Bad PSU? No. You couldn't run an i7-7700K on that, but I doubt that's the plan, given that we're looking at a Pentium G. You could run this system on a 430 watt PSU if he wanted to. Or a 250 watt. (Not that I recommend that. PSUs overall are worth going a little overboard on)
Overall, build looks fine. Are you planning on adding a graphics card or any other expansion slots later?
Everything I know I learned from the internet. Also school.
Current Desktop:
CPU: Ryzen 5 1600 @3.65 ghz, Cryorig H7
MoBo: Asus Prime X470-Pro
GPU: Gigabyte RTX 2060 Super OC
RAM: 2x8 gb Corsair Vengeance LPX DDR4 @2666mhz
PSU: 650W EVGA SuperNova
Storage: 120gb SK Hynix SSD, 240gb SanDisk SSD Plus, 1 TB 2015 WD Blue
Case: Corsair Carbide 100R
Peripherals: Logitech G Pro keyboard, Razer DeathAdder Elite, Logitech G305, Logitech G600, 24" AOC FreeSync 1080p monitor x2
https://linustechtips.com/topic/790353-my-first-build/#findComment-9958276
I do plan to add a 1050 ti it was supposed to be in the build list but I must have forgot it
https://linustechtips.com/topic/790353-my-first-build/#findComment-9961329
Cool! A 1050ti is a good entry level card. The Pentium G should be able to keep up with it no problem.
Current Desktop:
https://linustechtips.com/topic/790353-my-first-build/#findComment-9962947
