2nd Monitor Resolution help
kaiju_wars
So I have two monitors on my desk, much like a lot of people do.  My first monitor is the HP 25vx, it's a 25 inch 1080p panel.  The 2nd monitor that I got from a friend is the Dell ST2010B.
Here's the weird thing about this monitor, according to the user manual, Dell themselves, and even Windows all say this is a 1600x900 panel, but Windows gives me the option to set the resolution to 1080p.
Now, it displays 1080p fairly decently, but due to the monitor being 20 inches, things can get on the small side.
What I'm wondering is, is the resolution only 900p, is it 1080p, and should I set it to 1080p or leave it on 900p?
Currently focusing on my video game collection.
It doesn't matter what you play games on, just play good games you enjoy.
i believe there are programs to verify the resolution of monitors, so i would run one of those and find the true resolution of that panel
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
Go I to the monitors settings and see if you can change the resolution in there
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
I can.  Windows says that 1600x900 is the recommended resolution, but it lets me set it to 1080p if I want to.
Just now, Glenwing said:
Some displays support receiving higher resolutions than their panels are, and downscale the image to the panel's actual resolution.
Alright, thank you.
