Need help building a gaming pc.
13 minutes ago, Hoodedfiber27 said:I want a intel build. I already have a graphic card in mind, the gigabyte gtx 1060 xtreme gaming 6gb. I just need help choosing the other components. I have a budget of around 500$ for everything else besides the graphics card.
Nah man that's not how you build a PC. You get a GPU that combos well with a system, and that means that if you have to get a little lower-end card in order to fit some other important feature in there, you do it.
Since the Gigabyte 1060 6GB Xtreme Gaming is $280, I will give you a build for $780.
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor ($185.88 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard ($81.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2800 Memory ($58.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive ($87.88 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($48.44 @ OutletPC)
Video Card: MSI - Radeon RX 580 4GB GAMING X Video Card ($225.99 @ SuperBiiz)
Case: Cooler Master - MasterBox 5 (Black) ATX Mid Tower Case ($59.99 @ Amazon)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($44.99 @ Amazon)
Total: $794.14
Generated by PCPartPicker 2017-06-05 23:30 EDT-0400
Look at that. A really good gaming computer.
