Hi, i recently built my first PC, my build list is as follows, i5 7500k, Gigabyte b250 motherboard, 8gb ram, 1050ti GPU, 450 watt psu, 1tb hard drive. Here's my problem, my computer runs fine on basic web browsing or video streaming, but whenever i try to play a game the computer freezes and goes to either a grey or black screen; and either restarts on its own or i have to press the restart button. When this happens the computer is unresponsive to ctrl alt del. Ive tested it with the unengine benchmark and it warrants the same results. i swapped the Gpu for a replacement and the problem persist, without the gpu installed i can run the unengine benchmark all the way through. So am i looking at a bad pci e slot??? any help will be greatly appreciated.
https://linustechtips.com/topic/788468-someone-help/
What drivers are you running on your 1050ti?
HAve you tried the newest driver after cleaning out the old driver installs?
What bios version is your mobo?
check my PC build here: https://valid.x86.fr/jyjc2n
b350 tomhawk arctic h.51 bios, Corsair LPX ram running at 3200mhz
case is a 35$ Zalman Z3 plus white with a cooler master 10$ (15MIR)hyper t4 cooler
20$ EVGA 450w bt (black cables)
150$ 1060 3gb@2.1ghz
https://linustechtips.com/topic/788468-someone-help/#findComment-9933732
Try testing a different PSU?
CPU: Intel i9 9900K Motherboard: Asus ROG Strix Z390-F RAM: 32GB Corsair Vengeance LPX @ 3000MHz CL15 GPU: Gigabyte 1080Ti Windforce w/ AIO Liquid cooler Case: Fractal Design Define S Storage: 500GB Samsung 970 Evo NVME, 1TB OCZ Trion 150, 1TB SanDisk Ultra II, 2TB Samsung 860 QVO PSU: EVGA SuperNOVA G2 Gold 850W Display: 1440p 144Hz Acer XG270HU CPU Cooling: Noctua NH-D15 Keyboard: Logitech G Pro TKL Mouse: Logitech G403 Wireless Sound: Fiio E10k + Sennheiser HD6xx + Logitech Desktop Tower Speakers OS: Windows 10 Home
https://linustechtips.com/topic/788468-someone-help/#findComment-9933738
i  tried a program that wiped the drivers and reinstalled them and it didn't change anything, i could have done it wrong but who knows. And the bios version is F2
https://linustechtips.com/topic/788468-someone-help/#findComment-9933750
