USB C HUB
Go to solution Solved by iamdarkyoshi,
3 hours ago, Abhishake said:
ohh ok, what combo would you reccomend
Cheap ebay dacs can be found for under 99¢ but they don't produce very much bass oh headphones, speakers are generally okay. The only USB C device I have doesn't even support video out, so I've never looked for a USB C hub either.
For finding USB DACs, just search USB sound card and look for reviews.
Same for the USB C hubs.
If you're technically inclined, the output coupling capacitors in the cheap dacs just need to be changed to something around a couple μf, and it will produce bass on headphones.
Alternatively, if your monitor has an audio out based on HDMI/DP, you could use that.
14 minutes ago, Abhishake said:
Hey guys
I was looking for a usb c hub with hdmi, usb ports and headphone jack so that i can make my laptop like a desktop when i get home
Here take a look at this lots of options available:
-Moved to Peripherals-
https://linustechtips.com/topic/788430-usb-c-hub/#findComment-9933159
38 minutes ago, Abhishake said:
i already looked at those, none of them have headphone jack
If they have a USB port, you can get a cheap USB DAC
https://linustechtips.com/topic/788430-usb-c-hub/#findComment-9933781
6 hours ago, Abhishake said:
im not looking for a dac i was looking for a hub where i can run a hdmi, two usb ports and speakers through my usb c port on my laptop
But plugging a small USB to 3.5mm audio (dac) into a hub without one will essentially give you what you need
https://linustechtips.com/topic/788430-usb-c-hub/#findComment-9943021
https://linustechtips.com/topic/788430-usb-c-hub/#findComment-9957041
