so yesterday i tried to clean my cpu took it out of the socket and in the process i damaged the socket pins in mobo
i got a new mobo today gigabyte z270 gaming k3
when rebuilding the pc it couldnt boot with 2 ram sticks in mobo i upgraded the BIOS to F5 and it worked
although sometimes the pc froze and i had to reboot it but the pc goes to boot loop (fans start spining - stop and then start again)
i am running the pc with 1 ram stick atm formatted the disk reinstalled windows because i was getting blue screen all the time for many different reasons (when i entered my windows pass immediately blue screen)
now im doing the windows updates still with 1 ram stick i dont know how to solve this
http://www.gigabyte.com/Motherboard/GA-Z270-Gaming-K3-rev-10#support-dl
check that please
i have the F5 bios atm but F8b update is in beta al the f7 says that  i will not be able to downgrade to earlier version of bios
what should i do? update to the beta it has (ddr compatibility)
if something goes wrong with dual bios can i install the f5 again?
please help me its driving me nuts the whol day!
https://linustechtips.com/topic/788321-help-with-build/
 I would also recommend updating to latest BIOS especially for a relatively new motherboard (even if it's BETA).
Also, update the Firmware of your SSD if you are running one .. I had hang issues in my secondary build until I upgraded the SSD's firmware ..
Rig1LianLi O11 Dynamic Evo | Asus Crosshair VIII Formula | Ryzen 9 5950x  | 2TB Gen 4 | 64 GB  RTX 4090 | Samsung 49" 5120x1440
Rig2: TT Tower 200 | Asus X670e-i | Ryzen 9 7950X3D | 2TB Gen 5 | 64 GB  RTX 4090 | Samsung 57" 7680x2160  | Oculus Quest Pro
https://linustechtips.com/topic/788321-help-with-build/#findComment-9931975
ty i think now my pc is ok with 2 sticks
i cant find the lan ethernet driver for my motherboard..
pc was working fine for 1-2hours with 2 ram sticks suddenly it froze and on restart boot loop again!!!
now i can only run it with 1 stick
help me out pls its been 2 days im tryiung to fix this
https://linustechtips.com/topic/788321-help-with-build/#findComment-9932196
RAM speed is set to lowest in BIOS? Please make sure of that
https://linustechtips.com/topic/788321-help-with-build/#findComment-9935962
