Hey everyone!
After some ppl helped me with my color scheme Id like to show you guys the build i want to do, maybe you guys can tell me what you think about it :)
Its called bloodmoon and will have a mainly red/black theme with some purple accents.
The components:
I7 7700k cpu
Nzxt s340 elite red case
Asus strix z270f mobo
Gskill trident z rgb memory 16gb
Asus strix gtx 1070 rog gpu
Red sleeved cables
Cryorig r1 ultimate cooler
3x 140 / 1x 120 corsair ml pro red fans
1x 140 corsair sp purple fan
Thats the components :)
The gpu will light, the ram and led strip on the mobo in red and purple
About the cooler i have a question to you:
Since i think the stock fans are ugly af i want to switch the center one with a corsair sp140 fan. Also so the purple light of it will shine through the fins of the cooler.
Second is that id like to only use the center fan and not use the front one. Will this greatly affect my cooling performance? Note: i wont overclock the system
So what do you guys think? :)
Thanks!
https://linustechtips.com/topic/788286-bloodmoon-build-help/
3 minutes ago, Yuikura said:
Hey everyone!
The components:
I7 7700k cpu
Red sleeved cables
Thanks!
The cooling performance will  be fine. Temps may change 5-10C, without an overclock you will still be way way  under your thermal limits with a cryorig.
I was going to use ml pro fans for my build, watched a few YT vids that changed my mind as they are pretty, expensive, but louder than the SP140s.
Do you know for certain you like the purple light color with the red combination?
https://linustechtips.com/topic/788286-bloodmoon-build-help/#findComment-9931267
