First Pc Build
Solved by Zando_,
First off, welcome to PC awesomeness! Second, love the white theme! Third, your PSU could be better. It's a common mistake everyone makes the first time they build a PC or make a list. Better PSUs can protect your more expensive components like the mobo and CPU from freak voltage spikes and such, and they last longer, so they're worth getting. I'd recommend an EVGA G3 of you're sticking with EVGA, or a Corsair RMx series, or a Seasonic M12II for a solid full modular PSU under $60 USD.
EDIT: and here's a 650W PSU that's around $70 USD that @Ordinarily_Greater pointed me towards: https://pcpartpicker.com/product/R7V48d/seasonic-power-supply-ssr650rm
