Did you make sure to uninstall all other GPU drivers from your system before installing the new ones?
If not, make sure you use DDU (Display Driver Uninstaller) to do this. You need to use DDU to uninstall any driver from your PC before ever putting in a new card.
If you have, then just try DDU anyway and reseat the card.
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
https://linustechtips.com/topic/787841-help-meee/#findComment-9925971
No, never use that CD. Always download the latest driver from the website.
https://linustechtips.com/topic/787841-help-meee/#findComment-9925985
