Help///my intentions next week to custom build the following CPU: i3 7100 MB: ASUS gaming b250f RAM: 8GB DDR4 2400 MHz/ one stick Storage: SAMSUNG M.2 960 EVO 256GB no DVD no GPU no intention what so ever to overclock I am considering to install 400 watts PSU, according to pcpartpicker.com the total wattage is 166W roughly. the seller tells me to go for the 550Watts which in my opinion is overkill, so I am pretty confused!
if installed the 550W would there be problems or longevity be shorter???
https://linustechtips.com/topic/787812-help/
Seeing as your have no graphics card, 400W is fine. No, it will not harm your system if you have an overkill PSU, it wont use more than it needs.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/787812-help/#findComment-9925645
Well the person selling you a PSU was wrong. That system would struggle to draw 100W under max load.
Why are you getting an i3 though? The Pentium G4560 is basically a lower-end i3 for half the price.
https://linustechtips.com/topic/787812-help/#findComment-9926234
