So I know there is a certain point at which usb cables drop strength and degrade wen it comes to the length of the extension. So I had an idea for my next build. I want to keep it away from the desk and I want to put it up on a shelf about 1 meter away from my desk. So I plan on buying a 2 meter or 1 meter usb 3.0 extension and a 7 port usb 3.0 hub. I'm not sure what kind of limitation I would have using this but the devices I would be putting in it would be; keyboard, mouse, usb audio interface, phones, camera (logitech c922), and headphones. my only question is, would I be able to use them all like normal? would I be able to use the software to control the lighting? Would I be able to use software on the camera? Stuff like that?
https://linustechtips.com/topic/787112-usb-hub-and-extensions/
Most likely the only consideration would be the fact that the bandwidth for the USB hub would be spread over all the devices, so between them only 5Gb/s of bandwidth is available, which with just mouse and keyboard should not be an issue, however when transferring large amounts of data the single USB port used could be a bottleneck.
PC Specs
i7 6700
Asus H110-PLUS
ASUS STRIX 1070 8GB OC
EVGA G2 550W PSU
3TB HD & 255GB SSD
CiT Galaxy Evolution
Upgrades
EVGA G2 550W PSU
Asus Strix GTX 1070
NZXT S340 ELITE BLACK
https://linustechtips.com/topic/787112-usb-hub-and-extensions/#findComment-9917279
