Could someone help me design a custom PC start switch so that I would have to turn a key, flip a switch and press a button (after flipping switch and turning key little LCD screen would say primed) with a couple extra switches to specify what I want it to do (reset, shut down, turn on)? I know it's a bit silly but I think it'd be cool in the long run. I would need help making (or designing and sending to a company to be made) an enclosure for the electronics, programming the arduino (I think programming is required, yes?). But I am good with soldering General PC knowledge.
P.S. Switch would look something like attached picture
CPU: Ryzen 7 1800X
CPU Cooler: H100i V2
RAM: Trident Z RGB 16GB 3000MHz Cl 14
Motherboard: ASUS RIG Crosshair VI Hero AM4 ATX motherboard
GPU: 980Ti
PSU: Rm1000x
Storage: Samsung PM961 512 GB m.2 Nvme sad
Storage: 7500 RPM 2 TB Seagate Barracuda Hard drive
Case: 570X RGB (White)
OS: Windows 10 Pro
https://linustechtips.com/topic/786821-custom-pc-start-switch/
a raspberry pie some switches and some basic programming should allow you to do it. first go find a box of switches that you like
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/786821-custom-pc-start-switch/#findComment-9914065
I don't know how to go about it, but it shouldn't me too hard to make. I'd look into 3D printing the enclosure and misc parts, then find a makerspace (I think that's what they're called) near you with a 3D printer and use that. It would be cool. Especially if you hook it up to a PC with hardware legendary for overheating and spontaneously combusting.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/786821-custom-pc-start-switch/#findComment-9914066
wouldnt even need the pi.
just hook up the switches in series to the computers front panel power and itll work just fine.
really it would be super easy
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/786821-custom-pc-start-switch/#findComment-9914145
Yes, its not really that hard. You can even do something funny that will work, but inside it will look flimsy (no one looks inside though). Buy a remote switch, there are plenty of those to buy online. Then get the box you like. Glue remote inside the box aligning it so that when you push central button the box-button pushes the remote-button. So youll need remote right under your box-button.
If this does not work then you can disassemble the remote and instead of normal buttons solder to the remote the physical box-switches.
If you want the buttons to work only when the key is inserted and turned then you'll have to align the cables in such a way that the cables will connect only when the key is turned (without it electricity wont flow, so the buttons won't work). You'll have to have a separate battery and cable circuit to the LED that will not be part of the circuit between buttons and remote.
Good luck, it's perfectly doable with a basic understanding of electricity. The only issue might be to find a remote in which you can switch buttons to those in the box.
https://linustechtips.com/topic/786821-custom-pc-start-switch/#findComment-9920100
