When I was benchmarking my system I noticed that it has went in the low 20% CPU usage while in the benchmark is that normal for GTA V
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/786797-gta-v-low-cpu-usage/
Just now, TheRandomness said:
What're your specs?
I3 5020u 8gb of ram and Intel HD 5500 graphics
https://linustechtips.com/topic/786797-gta-v-low-cpu-usage/#findComment-9913743
How is it even playable?
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/786797-gta-v-low-cpu-usage/#findComment-9913816
What Hz are you getting? I'm just curious, but your iGPU is working as hard as you can get it to.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/786797-gta-v-low-cpu-usage/#findComment-9913859
My monitor is 60 but getting between 10-40fps
https://linustechtips.com/topic/786797-gta-v-low-cpu-usage/#findComment-9913983
36 minutes ago, Sentryy said:
your graphics are a bottlekneck to your cpu it seems
Ikr it's stupid how it's not supposed to do that
Lowest setting rendering scale 0.5 and some settings tweaked in the code for the shadows
https://linustechtips.com/topic/786797-gta-v-low-cpu-usage/#findComment-9913989
