big picture on xp
Go to solution Solved by AlwaysFSX,
I have Hyperspin hocked up with all the emulators and games to xp. It would take days of work to get the arcade running on windows 8.
Install XP on a virtual machine? I think Windows 7 professional has XP built in for a virtual machine so you could just copy and paste everything on to there while still being able to be up to date and use big picture. As far as I've tried, it doesn't work on XP at all.
Compatibility mode?
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/78675-big-picture-on-xp/#findComment-1080072
https://linustechtips.com/topic/78675-big-picture-on-xp/#findComment-1080158
Hello!
I know steam does not support big picture on windows xp. But is there a semi simple way to make it run on xp yourself?
I am building an arcade machine and i would rather not install a new os.
Tanks! /Kaninus
Best way: Upgrade from XP.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
https://linustechtips.com/topic/78675-big-picture-on-xp/#findComment-1091555
