I Had An Old Prebuilt PC Given To Me By A Guy Who Said It Had A Virus And Was Loud.
Dell Insiron 660s Specifically
Upon Quick Inspection, I Noticed That The Hard Drive Failed And The Whole Thing Was Full Of Caked Dust And Roaches. After Lots Of Brushing And Canned Air I Decided To Scrap The Old Case And Move Everything Into A Cheap DIYPC Case.
The Question Is With The Old Case Being A Slim Form Case And The New Case Being Standard ATX, Will Having Two Intake Fans And One Exhaust Hole Be Enough For A Basic Typing And Word System?
https://linustechtips.com/topic/786423-case-question/
2 minutes ago, Memorizer said:
You can get away with only 1 fan if you're just only using Word on that. So 3 fans will do you very fine.
Unfortunately I Have To Use Two 12mm Fans As Intake With One Large Exhaust Hole Because The CPU Can't Have A CPU Cooler Due To Clearance Issues.
I Am Rebuilding And Cleaning This PC To Sell Dirt Cheap, I Am $30 Into It And Want To Sell It For $100.
https://linustechtips.com/topic/786423-case-question/#findComment-9909058
Oh I misread what you wrote. :( I thought you have 2 intake fans and an exhaust fan. You can make the other fan as an exhaust if the case has poor airflow to release the hot air inside
https://linustechtips.com/topic/786423-case-question/#findComment-9909102
