Hey guys,just installed my new ryzen and mobo.After finally booting correctly and other stuff like installing gpu drivers etc i still have a red light lighten.It says "gpu led" and the manual says that i need to install a gpu but i have one running and working properly (even benchmarked it ).
Need some help pls, red led looks shit
https://linustechtips.com/topic/786255-msi-b350-pc-mate-led-bug/
This is normal for all MSI Ryzen boards and you shouldn't worry about it, it happens because theres no iGPU with Ryzen CPUs and the only theoretical way to fix it would be with a Ryzen APU. Hopefully an option can be included in a future BIOS to turn it off. For now you could use some electrical tape to cover it up.
https://linustechtips.com/topic/786255-msi-b350-pc-mate-led-bug/#findComment-9916371
