So im trying to pick out a motherboard and ive had my eyes on the asus maximus vi formula. The features it has on it are just outstanding, but ive noticed it only has 1 internal usb 2.0 port. I was planning to use the corsair h100i which needs a header and then there is the case header that i need to connect to. How can i fix this or are there any comparable motherboards?
https://linustechtips.com/topic/78560-usb-headers/
well you could grab a usb 2 to usb 3 internal header adapter
https://linustechtips.com/topic/78560-usb-headers/#findComment-1078178
Yea grab an adapter
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/78560-usb-headers/#findComment-1078210
