I've been playing Rocket League at 35 fps or lower, at the low video settings, and I am tired of it because it keeps jumping up to 40 and down to about 10. That is why this coming up summer, I'm planning to work at a store to get some money and upgrade my computer.
So, should I upgrade my graphics card or should I upgrade my CPU?? or should I buy a new $1000 computer... I need some bits of advice.
For CPU, I am planning to buy Intel Core i5 6600K. And for graphics, I don't know yet.... My budget, now, is about.... $4... #StudentLife. But I think I will buy it lower than $200. So I will be so appreciated if you guys can help me. Thank you!
My Computer details: (plus pictures)
Quote
Processor
AMD Athlon(tm) Dual Core Processor 4450B
Speed
2.3 GHz
CPU ID
178BFBFF00060FB2
Family
0F
Model
6B
Stepping
2
RAM
6.0 GB
Video Card
NVIDIA GeForce GT 730
Chipset
GeForce GT 730
Dedicated Memory
1.0 GB
Total Memory
3.0 GB
Pixel Shader Version
5.0
Vertex Shader Version
5.0
Hardware T & L
Yes
Vendor ID
10DE
Device
1287
Plug and Play ID
VEN_10DE&DEV_1287&SUBSYS_436019DA&REV_A1
Driver Version
21.21.13.7254
Operating System
Microsoft Windows 10 (build 14393), 64-bit
BIOS
Ver 1.00PARTTBLq
Version
Dell Inc. 1.4.
1
p/s: I am sorry if my post is in the wrong category. #newbie
https://linustechtips.com/topic/785463-need-upgrading-advice/
save your money for a ryzen system.
https://linustechtips.com/topic/785463-need-upgrading-advice/#findComment-9898776
The only thing you could reuse are the 2 HDD I see lying at the bottom and the optical drive on top.
Then with a $1000 budget left you can crate a new PC from scratch as the components you have are pretty mch useless and obsolete already
I am unsure if that case can support long GPU so you should get a new one too
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($218.58 @ OutletPC)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  ($96.89 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($115.99 @ Newegg)
Storage: Western Digital - Blue 250GB 2.5" Solid State Drive  ($83.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1070 8GB Windforce OC Video Card  ($372.16 @ Amazon)
Case: BitFenix - Comrade ATX Mid Tower Case  ($29.99 @ NCIX US)
Power Supply: SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($56.99 @ SuperBiiz)
Total: $974.49
Generated by PCPartPicker 2017-05-28 00:09 EDT-0400
https://linustechtips.com/topic/785463-need-upgrading-advice/#findComment-9898781
Total: $974.49
3
Oh, thank you much <3 I will try to get those! <3 and one question: if I go the upgrade path, which CPU (or graphics or both) should I buy?
https://linustechtips.com/topic/785463-need-upgrading-advice/#findComment-9898792
At this point in time, both your CPU and GPU are very out of date. Only upgrading one or the other would lead to bottlenecking issues. The parts list by deXxterlab97 seems to be pretty reasonably priced. If you don't want to pay almost $400 for a GTX 1070 and would be fine with a mid-range card, you can consider getting an RX 480/580 or GTX 1060 instead. The cheaper models usually run between $150-200 during sales.
i7-6700 @ 4.4GHz || Asrock Z170 Pro4 || MSI RX 480 Gaming X 8GB || Sandisk 480GB SSD + 2x Crucial 128GB SSD + Seagate 3TB HDD
2x8GB G.Skill 2133MHz || NZXT S340 || Cooler Master Hyper 212 Evo || EVGA B2 750W || AOC G2260VWQ6 Freesync
https://linustechtips.com/topic/785463-need-upgrading-advice/#findComment-9898795
Yeah, I can see it because sometimes just by watching HD youtube videos, it stops for a couple of secs to render, and then it plays back, and then it continuously repeats (obviously not my internet connection). Thus I think it is because of the CPU. In the same time, I want to upgrade my gaming experiences... so... yeah thank you, Hobo <3
https://linustechtips.com/topic/785463-need-upgrading-advice/#findComment-9898810
