SUB FOR UPDATES
First time using Sketchup and frankly, its a tad tedious. It's cumbersome. Not a hard learning curve but definitely annoying. I would draw lines and they would just stick. I guess I'm just used to AutoCAD but oh well :D
What do you guys think of these renders?
It's for a potential mITX in a custom case.
post-22241-0-19541300-1384999148_thumb.j
post-22241-0-23003800-1384999251_thumb.j
any tips tricks? I drew tubing prior to installing RAM as you can tell. :P
***UPDATE***
post-22241-0-35340400-1385044657_thumb.j
post-22241-0-59849700-1385044655_thumb.j
post-22241-0-08708200-1385044666_thumb.j
post-22241-0-76135900-1385044653_thumb.j
post-22241-0-61853000-1385044664_thumb.j
post-22241-0-34377300-1385044662_thumb.j
post-22241-0-88656700-1385044659_thumb.j
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/78542-mitx-sketchup-build/
If you want to have the pc be smaller switch the psu for a sfx one. It looks pretty good, but I would use the psu as an exhaust when you design the case so you have some air being pulled out.
https://linustechtips.com/topic/78542-mitx-sketchup-build/#findComment-1077898
Its a steambox! I am great at pictionary  :P
ya!!! it could work as one
i was thinking of having the rad setup as one side pull and the other push.
the case would have a vent at the top for the GPU. i might add a different PSU later :)
https://linustechtips.com/topic/78542-mitx-sketchup-build/#findComment-1077920
Woah, that's amazing!
| Case: NZXT Tempest 210 | CPU: Intel Core i5 3570K @ 3.9 Ghz | GPU: ASUS ROG STRIX GTX 1070 | RAM: Crucial Ballistix Tactical 8GB |
| Mouse: Zowie FK1 | Monitor: Acer 21.5' | Keyboard: CoolerMaster Stealth w/ Brown Switches |
#KilledMyWife - #LinusButtPlug - #1080penis
https://linustechtips.com/topic/78542-mitx-sketchup-build/#findComment-1077951
everything looks fine but the tubing looks like it got fucked up and it's really small on of the tubes
Ya I added the RAM first :P and tubing's a pain in the a**
Its pretty easy :P
I would spin the rad so that the fans are facing you.
The barbs are closer to the block though
https://linustechtips.com/topic/78542-mitx-sketchup-build/#findComment-1078004
Put that in a large cube with a disk tray on top, and you got a Gamecube.
im actually designing the case ATM.
going for a wooden with tons of plexiglass
The PSU looks to real for me =P
maybe it is...real
https://linustechtips.com/topic/78542-mitx-sketchup-build/#findComment-1078642
