Help With Fans?...
Go to solution Solved by Marinatall_Ironside,
Your best bet is to get a SilverStone CPF04 8-way PWM fan hub. You would hook up the first channel to a 4-pin PWM header on the motherboard and then you can control up to 8 PWM fans at the same time, with power provided by a SATA connection. You cannot use 3-pin fan with this hub. If you are going to use 3-pin fans, then a ModMyToys 4-pin Molex to 3-pin fan power distribution in an 8-way block will do the trick.
SilverStone CPF04
ModMyToys 4-pin power distribution PCB - 8-way block
Hello everyone,
I have been learning all the ins and outs of everything PC for the last 2 weeks or so, and i need some help here.
For whatever reason, i can't wrap my head around fans.
I know that there are 3 and 4 pin connectors, and that some fans are either connected to the PSU or to the MOBO.
That's the result of roughly 4 hours of googling, looking up tutorials, scouring through forums, etc.
So i ask of you, please, help me out a bit here?...
(Parts):
Case: "Fractal Design Define Mini C" (Manual)
Motherboard: Probably the "ASRock AB530M-Pro4" (Manual)
CPU: "Ryzen 5 1600" (stock cooler)
GPU: "Gigabyte GeForce GTX 1060 6GB WindForce OC"
PSU: "SeaSonic M12II EVO 520 Watt Modular"
Questions:
If i were to get another 120 mm front fan, how would i hook all this up?
Would i hook up the back fan to the 4 pin connector, and one of the front fans to the motherboard?
What would i do with the third fan, or could i get some kind of splitter that would allow me to plug 2 fans into one connector?
What is the exact difference between a 3 and 4 pin connector?
Would i need some kind of external controller to control the fan speed of my fans, or would the system handle the speed itself?
Any further information on setting up fans, and possible examples or suggestions are always welcome!
Thank you for your time. :)
https://linustechtips.com/topic/785250-help-with-fans/
SilverStone CPF04
Edited by JurunceNK
added fan hubs
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/785250-help-with-fans/#findComment-9896642
3 minutes ago, JurunceNK said:
Your best bet is to get a SilverStone CPF04 8-way PWM fan hub. You would hook up the first channel to a 4-pin PWM header on the motherboard and then you can control up to 8 fans at the same time, with power provided by a SATA connection.
Thank you for that one! :D
Sadly, after a bit of searching, i fear that this model splitter is not for sale in my country, the Netherlands, or at least not easily obtainable.
I'll look around for a bit and see if i can find something on it, or a similar alternative. :3
Also, regarding the speed control of the fans, i am assuming that it would be handled automatically, as there is no control interface or anything?...
https://linustechtips.com/topic/785250-help-with-fans/#findComment-9896662
For the 4-pin PWM hub, you control all the fans through the motherboard's BIOS.
For where you live, go to HighFlow. They're a PC modding specialist country in The Netherlands ;)
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/785250-help-with-fans/#findComment-9896790
Damn, thanks!
Definitely gonna keep this one bookmarked... ^^
Cheers mate! :3
https://linustechtips.com/topic/785250-help-with-fans/#findComment-9896907
