Just now, paddy-stone said:
I haven't tried that mobo TBH, so don't know, but almost any mobo should eb able to handle that OC as it actually only uses very little extra voltage compared to stock voltage, plus I don't trust auto voltage, I have seen auto voltage peak waay too high. You could have a look at this mobo https://pcpartpicker.com/product/dWL7YJ/asrock-ab350m-pro4-micro-atx-am4-motherboard-ab350m-pro4
I have this one myself and has some great features for the price it is, and has decent power phases to give clean energy to the CPU, just check the QVL list though to make surte your ram will run at speeds you want.
Ok, thanks so much!
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895847
Oh- I notice the mobo you listed says micro ATX. Does that matter, or is it irrelevant?
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895851
Just now, yodaobiwan1 said:
Ok, thanks so much!
No problem, if you have more questions or anything I'd be happy to help if I can.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895852
No, it doesn't matter at all, just has less PCI-e slots and is a bit smaller... if you have a pc partpicker list I'll have a look for you and try to check if there'd be any problems for you.
[edit] it's ok, i have the partlist now from first page.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895860
 https://pcpartpicker.com/list/
same as above.
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895862
same as above.
May I ask what your budget is please, I want to see if I can get you a better choice for some parts.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895868
About 800-900. I could go to about 1k, (USD) but would rather stick to below 900.
OK, cool I can work with that for sure, i'll try to keep it low as possible, but with decent parts :)
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895874
OK, made a few minor changes and added an SSD in m.2 form factor, this will make it much snappier feeling to have an SSD, but if you don't want it just remove it from the list :)
PSU is now fully modular, ran is better and so on, hope you like it.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895905
Also, is there a large difference of performance between the 1070 and 1070-mini?
No, the mini card is very good actually and is a great price too. If you have more budget to use though, you could get the bigger card, but won't make much noticeable difference IMO.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895910
https://pcpartpicker.com/list/xRCj9W
Sorry forgot to add the list, lol
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895912
Cool, thanks so much!
No problem, if you have concerns or want to make some chnages I don't mind and am willing to help you further :)
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895917
Whats do you mean by the PSU is fully modular? (I'm new to this if you haven't figured it out already xd)
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895918
It means the PSU leads aren't fixed on the PSU at all, so if you don't need some cables for instance you can leave them out of the case rather than having to cable manage them, makes a much neater build :)
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895921
OK, cool! Does this make it any harder/easier to assemble?
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895926
Much easier to assemble, you pretty much only need to attach the CPU lead, 24 pin motherboard power lead and GPU power and SATA lead for the HDD you have.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895932
No problem, that is an awesome system, especially to start with :)
You have options for the future this way for sure.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/785178-i-need-help/page/2/#findComment-9895948
