Hello, so It's finally time for me to upgrade my fractal design r3 120mm fans. I was thinking to go with Noctua NF-P14s redux-900 140mm
Now, would it be bad if I replaced all 120mm fans with 140mm, but I cannot have a 140mm in the rear of my chassi, so that means
2- 140mm front
2- 140mm top
1-120mm rear
Would that be okay? Or should I just go with 120mm all around?
-Thanks
https://linustechtips.com/topic/784622-fan-question/
It's fine it doesn't matter what sizes it's air flow thy matters
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/784622-fan-question/#findComment-9889220
So it doesnt like give negative airflow or something? It's fine putting 140mm fans and 120mm fans in the same case? Should I always try and get 140mm fans where I can and just 120mm where a 140mm wouldnt fit?
https://linustechtips.com/topic/784622-fan-question/#findComment-9889302
It's more positive air flow it's just fine
https://linustechtips.com/topic/784622-fan-question/#findComment-9889432
If you have 2 front intakes, 2 top exhausts and 1 rear exhaust, thats negative to start with. 2x140mm move more air than 2x120mm. But if there's anything in way of airflow, it becomes less effective. So 2x140mm front in and 2x120mm top out running at same speed would be close to neutral.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/784622-fan-question/#findComment-9891036
What case do you have?
https://linustechtips.com/topic/784622-fan-question/#findComment-9904130
9 hours ago, spree said:
Phanteks p400s
Either 3x120mm or 2x140mm front intake would be fine.
What are you swapping out your fans for?
https://linustechtips.com/topic/784622-fan-question/#findComment-9907050
Just now, spree said:
See original post
I don't see an answer in the OP.
https://linustechtips.com/topic/784622-fan-question/#findComment-9907080
Oh, I used a poor choice of words. I was asking about why you were replacing your fans. What sort of improvement are you looking for?
https://linustechtips.com/topic/784622-fan-question/#findComment-9907146
2 minutes ago, spree said:
Mostly noise level.
What speed are you running the R3's at?
Do you have a 120mm in mind for the rear exhaust? If you like Redux colors, a NF-S12B would be good.
https://linustechtips.com/topic/784622-fan-question/#findComment-9907200
