SLI Noob need help
Solved by Aynethol,
15 minutes ago, Simon771 said:Well running GTX 1070 in SLI will yield you much better performance in games that support it and scale well.
It's also great for your showing off benchmark score
It depends if you acctually need more GPU power.
If I were you, I would sell both of those GPUs and get single 1080 ti. But before that I would SLI those 2 cards and run all the benchmarks just for my own pleasure.
You know it never considered on me just to sell them on then get a 1080ti!
Your right, thanks for all the help man!
