Will initializing a drive wipe it?
Go to solution Solved by EunSoo,
10 minutes ago, Lord Nicoll said:
yes, it will wipe it, only do this for new drives that haven't been used as a general rule
8 minutes ago, SCGazelle said:
oh ok. How can I get it back without initializing it? I guess I'll try replugging it into the motherboard.
it's back. I guess all it wanted was some attention.
So I was editing a video in Premiere and one of the clips was on a 1tb HDD that is plugged into the motherboard. I tried previewing the clip in Prem and it froze. I thought it was because of RAM (i only have 8gb in this machine, it wasn't full tho) so I tried viewing it in VLC which also crashed (i just needed to get the timestamp for a frame on the clip). I restarted my PC and when I go to file explorer the entire drive is gone. When I open Disk Management it says that the drive needs to be initialized before it can be used. Will initializing it do anything to the data on it? Thanks
https://linustechtips.com/topic/783752-will-initializing-a-drive-wipe-it/
Yours faithfully
