Forgive my paranoia, but this is my first loop. I put it together over the weekend, and the level in the reservoir has dropped ever so slightly a time or two. I checked around but no leaks anywhere. That's just air hiding in the loop (most likely the radiator) escaping and making it's way back into the reservoir, right?
https://linustechtips.com/topic/783435-coolant-level-question/
It's fairly normal for a new loop to have a drop in liquid level from air bleeding out of the system. Just keep an eye on it and make sure it's not continue to dropping overly rapidly.
https://linustechtips.com/topic/783435-coolant-level-question/#findComment-9875003
Of course, I can usually see pretty well where all the fitting connections are, so I'm always looking, just wanted to verify that it was normal
https://linustechtips.com/topic/783435-coolant-level-question/#findComment-9875006
Gonna evaporate and pump speed will also effect the level. I have one loop with a breather that looses a lot of fluid.
https://linustechtips.com/topic/783435-coolant-level-question/#findComment-9877619
