Radiator fan question. Also what is that extra cable??
49 minutes ago, BrandonIsComputering said:What is SIV? Also, I just purchased another corsair sp120 but the pwm version along with some 3pin extensions to connect my 3 120mm in the front. I was wondering, could I connect the pwm hub connector to the systfan header and the fan I'm putting onto the rad onto the cpu_fan. From what I understand, the systfan header is pwm but voltage regulated so fans won't boot up until about 20% and up? I'm just paranoid to not have complete control over the radiator fan.
SIV is Gigabyte's System Information Viewer. https://www.gigabyte.com/FileUpload/Global/Microsite/369/images/system-tweaking.html
The pwm hub needs a pwm header to work. In this case, that would be your cpu_fan and not a sys_fan header.
You can plug the Aer P140 fan into the case fan hub but it won't be getting the 4pin pwm signal that its designed for.
The minimum fan speed depends on the fan itself.
