Building a Computer right now, no post
Go to solution Solved by Jon No H,
Okay, I feel terrible now, I've been doing research on my parts, and I have server RAM, so I'm so sorry about that but it was not clear, thank you for all of your help
do you have an error code on the motherboard? What board is it?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Just now, Siphx said:
Where would I look for an error code, it is an A68HM-E33 V2
doesn't look like it has one try with one ram stick, check all wires are connected
Ryzen Ram Guide
try the stick in the other slot. Triple check those connectors, are you able to post a picture of the inside of the PC?
Ryzen Ram Guide
Okay I'll try the other slot, triple check the wires, and that picture will be up shortly
Just now, jnvqc said:
So the fan spins?, what CPU is that, if it it is an APU take out the gpu and connect the video connectors directly on the motherboard.
Yes fans spin (except my system fan 1, my outake but may just be old) I'll take out the GPU and hook it up to integrated graphics
Is the beeper plug in, any beeps? Does it turn off and on a cycle? Any lights on the motherboard?
I don't know what a beeper plug is, no beeps. It does not turn off and on. I'm not sure about any lights on the motherboard
