Where do I plug in this 2-pin fan?
Solved by chexor,
45 minutes ago, ShadyOrb09 said:The first picture is of the actual fan I want to plug in, the second picture is of the fan controller I have, in the picture it's plugged into another fan I currently have plugged in. If I was to plug it into the 4 pin CPU fan port on the motherboard would it work?
My advice, plug them directly to PSU. Cut connector from wires, remove isolation and hook them up in any molex adapter (you can buy for 1$ or cheaper) red is + black is - for psu that means black is - and yellow is + (go red with psu-yellow and black with black, if its 5v cooler then you go for red-red wire) You cant demage your psu with this, worst thing that you can kill cooler i guess if you mess up something..
