CASE
11 members have voted
  1. 1. Which One
    • Phanteks EVOLV ATX (NON-TG)
    • NZXT S 340 ELITE
      7
    • NZXT NOCTIS 450
      2
    • CoolerMaster MASTERCASE Maker 5t
      1
    • Other
      1
I am currently planning for my first build during the summer and looking for good , clean , friendly ATX case
I have got them down to 4 options and I need help to choose the best one . Please help me out and tell me which one to chose and why
Phanteks Evolve ATX ( NON-TG)  - Everyone seems to think this is an amazing case and a pleasure to work with
S 340 Elite by NZXT - I think it is the one I saw most on the forum here and seems very simple
Noctis 450 - a better H440 perhaps and probably the best looking choice
CoolerMaster Mastercase Maker 5t
Other suggestions are welcome too
Thanks In Advance
Before you reply , wait a couple of minutes after the post's time stamp since I usually edit right after posting. Also please read the post carefully.
Current Rig:
Intel i7-7700k @ Stock / ASUS STRIX Z270E / NZXT Kraken x62 / 16GB (2x8GB) DDR4-3000 Corsair Vengeance RGB LED / Samsung 960 Evo 250GB / WD Blue 1TB / Seasonic-X 650w / Windows 10 Pro x64
https://linustechtips.com/topic/783207-help-choosing-a-case/
NZXT cases are beautiful. i am biased towards good looking cases rather than functional cases.
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872178
In my personal opinion and experience, the Phanteks EVOLV ATX didn't have enough airflow to maximise cooling potential.
I'm currently using an NZXT S 340 Elite (white) which looks beautiful and sleek. It's relatively simple to work with, thought it's a bit tight on cable management space compared to the Phanteks Evolv ATX.
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872185
Yeah both are really cool the S340 Elite is the more minimalistic one while the 450 just look badass ; I hoped you would choose one but thanks anyway
Current Rig:
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872190
I'm not actually a fan of the 450, it looks a bit 'childish' in my opinion. As if it's trying to hard to look 'gamery'.
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872197
Just now, tochi de kawaiidesu said:
Also that the NZXT S 340 Elite is considerably cheaper is another bonus.
Money isn't an issue as long as it is under $200
I am going to use an AIO for the CPU but your experience with bad airflow is concerning
Thanks for your input though
Current Rig:
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872198
Well true they even made an ROG edition
Current Rig:
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872199
Thanks In Advance
I have a regular S340 and have built in I think 3. They're easy to work with and look simple and pretty if you put nice hardware in em.
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872202
3 builds gives you alot of experience with the S340 does it have any major issues with cooling or other stuff
Current Rig:
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872208
I'm not sure if this helps but, I'm currently running: Intel 5820k at 4.6GHz overlock, GTX 1070 ROG STRIX, Corsair LPX Vengeance 2x8GB (white) and an AIO watercooler from Deepcool, with an EVGA MICRO 2. IT all works nicely, running at an idle on the cpu of around 35 - 40C and the gpu idle at 35. (it's usually lower, but it's a warm day out today (23C... Okay it's warm for england xD)
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872209
Also forgot to mention, I've locked the gpu fans to 25% to reduce noise as it's litearlly 50 cm away from my face.
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872210
The cooling is actually fantastic in that case but there's not enough room for SLI plus SSDs on the showcase bit underneath where the GPUs go. You'll kill cells in your SSD if you do that.
If you ever built in the original S340 the dust filter was straight garbage but they fixed that. The included two fans are also pretty decent too.
I really can't think of any serious flaws with it. It's sturdy and has plenty of features for the $60 I paid for it. The Elite has one more SSD bay and has tempered glass. It's a bit plain so you gotta make it look pretty with colorful hardware.
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872220
Can you post some pics when your doe i want to see how it turns out i voted for the NZXT S 340 ELITE because it looks badass
Main rig                             I also got some cheep lg phone and a chromebook, witch I have been known to mine bitcoin on sometimes
CPU: R5 2400g
RAM: 8gb ram
MOBO: msi b350 pc mate
CASE: Eclipse p300
PSU: 500w corsair
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872258
Well yeah it helps that you are not facing any problems with it cooling wise ;I was leaning towards the Phanteks because of the extra fans on the top and I thought it would be superior to the others in airflow but as you said it had issue while  you are not facing any problems with the S 340
Thanks again
Current Rig:
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872362
 Thanks for the helpseems to be a pretty good case ; although am surprised no one is talking about the Phanteks Evolve although it the one I was leaning towards
Current Rig:
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872368
Sure , although it might take some time since I am building over the summer and still has alot of stuff to figure out
Current Rig:
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872372
I say "eh" to the Evolv's airflow.
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872475
yeah seems that there is an issue with the evolv's airflow although it has (on paper) a very good airflow system something is wrong
Current Rig:
https://linustechtips.com/topic/783207-help-choosing-a-case/#findComment-9872485
