Hi,
I was wondering if you could setup F@H on a remote machine and have all the points and stuff still contribute to the same 'account'. In my case, I only have command line access via SSH. I looked at the F@H pages, and whilst they did give all the commands needed and stuff, it did mention that it wasn't meant for 'command only' linux.
Would you guys have any help on this? I think i've seen a few of you mentioning having F@H running on a VPS, so I would assume it is possible.
https://linustechtips.com/topic/782844-fh-on-remote-machine/
Well i know that in theory it works to have multiple machine contribute to the same account and all, but no idea how to do it via command, sorry.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/782844-fh-on-remote-machine/#findComment-9868262
Oh ok. Well, to set it up to have it on multiple normal machines, how would you do it?
https://linustechtips.com/topic/782844-fh-on-remote-machine/#findComment-9868264
You just download the client and set up your username, passkey and if you want team to fold for (e.g. LTT)
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/782844-fh-on-remote-machine/#findComment-9868271
Oh okay. The passkey would be what links your accounts, right? If yes, then the command-line version of F@H does prompt for all of those, which is nice. My only concern is then to be able to see how much work it is doing, as I believe you cannot see any of the stats from another computer?
https://linustechtips.com/topic/782844-fh-on-remote-machine/#findComment-9868284
