Hello guys,
Just wanna know if this build will be able to run top games like GTA 5 and Tomb Raider 1080p or even 1440p at 60fps.
Ima newbie so any help is appreciated..
i5 6400 3.3GHz
GTX 1060 6GB DDR5
H110M Pro motherboard
8GB RAM DDR4
1TB HDD
Is the processor ok and enough to run these games?
https://linustechtips.com/topic/782668-newbie-help/
tomb raider at 1440p 60fps with gtx 1060 is like finding a unicorn. my 480 4gb at 1080p sometimes drop down to 40fps max settings at 1080p
you need at least 1070 or 1080 for 1440p
and I highly suggest getting R5 1600 instead
if you have limited money to spend then don't think highly of 1060 as a 1440p card
https://linustechtips.com/topic/782668-newbie-help/#findComment-9866479
some 1060 models are able to do 1440p gaming. Not all of them though.
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/782668-newbie-help/#findComment-9866499
With that hardware you'd have a much better experience at 1080p. Also, have you bought it yet or are these parts you will buy?
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
https://linustechtips.com/topic/782668-newbie-help/#findComment-9866501
They're all based on the same card, so the results won't differentiate to the degree you're thinking about. If you're referring to the difference between the 3gb and 6gb cards, then yes, the performance jumps when you go from 3 to 6.
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
https://linustechtips.com/topic/782668-newbie-help/#findComment-9866507
7 minutes ago, DiabeticNinja said:
It's mainly 1080p I'm aiming for but just wondering how it would fair at 1440p.
I would like to play GTA 5 at high/ultra at 1080 mostly so just wondering how GTA,TR would fair at 1080p.
I have not bought parts yet...thanks for replies guys
my 1060 runs TR fine at 1080p with max settings. Dunno about gta 5 though
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/782668-newbie-help/#findComment-9866564
the 1060 will play games at 1440p high-ultra depending on the game.
https://linustechtips.com/topic/782668-newbie-help/#findComment-9866575
