Get a full glass case like the corsair crystal 460/570x, and just get a wackton of RGB Fans and strips.
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
https://linustechtips.com/topic/782659-rgb-case/#findComment-9866492
Thanks so do you know any rgb strips that is asus aura ready? Oh I'm also Australian so if possible an Australian link would be best  Thanks
https://linustechtips.com/topic/782659-rgb-case/#findComment-9866538
Just now, Helitagging said:
Thanks so do you know any rgb strips that is asus aura ready? If so thanks
Cablemod has strips that are advertised as compatible with it, so they're a safe bet.
https://cablemod.com/product/cablemod-widebeam-magnetic-rgb-led-strip-60cm/
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
https://linustechtips.com/topic/782659-rgb-case/#findComment-9866551
Thanks I also wanted to know if I did get the corsair case is it possible to connect the rgb fans to my Maximus xi formula mobo and be controlled by the aura software thanks
https://linustechtips.com/topic/782659-rgb-case/#findComment-9866658
I don't think so, you could look at getting a different case that has sufficient glass and get case fans like these that are compatible.
http://www.coolermaster.com/cooling/case-fan/masterfan-pro-120-ab-rgb/
I believe the reason the Corsair fans aren't compatible has something to do with pin polarity and voltage, if im not completety wrong.
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
https://linustechtips.com/topic/782659-rgb-case/#findComment-9866673
Ah well that sucks I was hoping it was compatible but I guess I was wrong, I guess have to go pm another journey to fine another case but thanks for your help anyways
https://linustechtips.com/topic/782659-rgb-case/#findComment-9866717
No problem, hope I assisted you in you journey :P
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
https://linustechtips.com/topic/782659-rgb-case/#findComment-9866724
5 hours ago, Helitagging said:
I am looking for a fully rgb case that can be controlled using the asus aura software so it can be synced with all my asus components so if their is a stunning case that is rgb can you let me know thanks
@Helitagging our LED strips are ASUS Aura compatible with the included adapter in the packaging.
The Crystal cases would be just fine for our strips as well, as there is steel construction throughout the case for the strips to grab on to.
https://store.cablemod.com/products/?filter_series=magnetic&filter_product-category=led-strips&filter_color=rgb
https://linustechtips.com/topic/782659-rgb-case/#findComment-9867619
Thanks so the cable mod can be plugged into the Maximus xi formula mobo and be controlled using the aura software?
https://linustechtips.com/topic/782659-rgb-case/#findComment-9869879
I have the Corsair 570x and the included sp120 RGB are not Asus Aura compatible. out of the box the only way to change the color is to use the three buttons at the top of the case Options are fairly limited though You can use a Corsair Lighting Node Pro to manage them in Corsair Link, which is another option. As the lighting node pro comes with LED strips, if you install them you will be able to control both the strips and the fans in corsair link.
For the Sp120 RGB fans, each of them have 2 cables (non-PWM power and LED control). The LED cable connects to a controller that comes with the case. From there, you can go to the buttons at the top of the case or to a lighting node pro controller.
In my case, I changed the included fans for HD120. I find the color more bright and they are PWM ;) Be aware that the LED controller for the fans aren't compatible between the two, but both are controllable using the lighting node pro ^^
https://linustechtips.com/topic/782659-rgb-case/#findComment-9870045
Ok thanks for letting me know so if I get hd120 three pack fan with the corsair lighting node will it all fit inside the corsair 570x without taking any of the pre installed fans
https://linustechtips.com/topic/782659-rgb-case/#findComment-9870139
Yes all the fans will fit. Problem is you won't be able to control the LED strips + HD fans + SP fans with one Node Pro. The node pro has only 2 plugs on it x)    I have the same problem, I got one for the HD fans and the led Strips, but I need a second one for the SP fans :(
Be aware that if you use a radiator and want to put it in the top spot, it will be really tight with the RAMs. You won't be able to do push-pull in the top if you have high-profile RAM sticks. This was also a problem for me, I wanted to install there a corsair h100i v2 in push pull, but there isn't enough space.
https://linustechtips.com/topic/782659-rgb-case/#findComment-9870194
Ok thanks for letting me know I'll get air cooler and all Sp fans and one node pro
https://linustechtips.com/topic/782659-rgb-case/#findComment-9870263
