Yesterday unknowingly some application installed later I got to know the effect it was an adware I was frustrated over it then did a clean installation.. Of windows 7 after sometime (like when I linked the Google chrome to my google account) again the adware started working... I don't know what's happening. Can a account be lined to adware? Is it possible? I'm stuck can't do anything in this point and I don't know how to fix this annoying thing..
https://linustechtips.com/topic/782127-adware-issue/
If it got in as a chrome plugin yes. Check those out and see if it can be found there. From there a deinstallation should be pretty easy.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/782127-adware-issue/#findComment-9860609
Well I did all I could means I went to local disk c then whatever was uncommon (some Chinese shit) was there deleted and uninstalled it... Bt one application called search2find is not uninstalling... I don't know why..  I tried many ways... But couldn't...
Edited by Dave8798
https://linustechtips.com/topic/782127-adware-issue/#findComment-9860617
