Hi Everyone and Welcome to the start of my first Build Log on this Forum!
I'm here with an idea that I have not seen anywhere else during my countless hours of forum jumping, which is doing a Custom Water-Cooling Loop inside of the Silverstone SG13. I have every intention of working my hardest to make this the best build I've ever done. I will be jumping past many barriers that I had thought unthinkable for myself to do, one of which will be designing and constructing a Custom Cooling Loop. I know I am taking quite a challenge in by using such a small and compact case, but that challenge is one that I am willing to face. So here marks the beginning of the build log, I hope that you choose to stick along with me in my endeavor. Thank You.
With this being the Initial post of this project, many of the components have not been finalized.
But within the coming few weeks, I look forward to share my choices for each.
Computer Components:
CPU - [Not Chosen]
Memory - Corsair Vengance LPX 16GB (2x8GB) @ 2666MHz
Motherboard - [Not Chosen]
Storage - [Not Chosen]
GPU's - EVGA GTX 980Ti Superclocked+ ACX 2.0+
Case - Silverstone SG13B
PSU - [Not Chosen]
Water-cooling Components:
CPU Block - [Not Chosen]
Radiator - [Not Chosen]
Pump - [Not Chosen]
Fittings - [Not Chosen]
Tubing - [Not Chosen]
Coolant - Mayhem's Pastel Ice White
Other Components:
Lighting - NZXT Hue +
With a build like this, there are also some other things that I would like to do so I can have my work stand out from others. Most of these will most likely not be incorporated into the final build as I have many ideas for this project, but am unsure about which would look the best.
Planned Mods (No specific order)
- Custom PSU Cables
- Side/Top Panel Window
- Custom GPU Backplate
- Custom Anodizing of RAM Heat-Spreaders
https://linustechtips.com/topic/781673-project-esprit-sponsored/
maybe fix it for dark theme?
Builds:
https://linustechtips.com/topic/781673-project-esprit-sponsored/#findComment-9855500
