Laptop cooling pad fan noise and heat on the cooling fan
Hi, I was wondering if this sound and heat is alright? After a few minutes of use it feels warm on both fans. Also this laptop cooling fan makes noise too when I put my ear near it. The laptop cooling fan comes with the fan pulling heat away from the laptop but I've reversed it to provide some airflow to the laptop the laptop already have its own exhaust. The video taken is before flipping the fan to push the air to the laptop.
What's the laptop model? Full specs?
What's the idle and load temps for CPU (and dGPU if got)
Mind taking some pictures?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
I meant the laptop cooling pad, the laptop have no problem, just wondering about the cooling pad, sorry for the inaccurate title
Cooling pad usually sucks, some even blow hot air into your laptop so be aware
The sound and heat is normal.
Desktop specs:
Yeah the motor also will heat up
Desktop specs:
Some fans, including of the newer EKWB-Vardar feature of diminutive cut outs on the central motor housing to which effectively cool the motor as airflow movement happens. Although I doubt such could be implemented on a cooling bad, the noise could possibly be turbulent noise.
 I could not understand the use of a 'cooling' pad however if temperature isn't of concern, but if you had previously orientated the fans in an opposite direction, re do of such to see if that makes of a difference.
I once did the unthinkable, back many headphones ago...
I split an audio split, again
Did you mean by pulling air from the laptop or pushing air to the laptop?
