Probably because normal cases are placed vertical and heat can rise and escape through the top. While desks are more horizontally and need good airflow for the heat to leave. Also the materials used like wood and glass absorb the heat more than aluminum and metal.
https://linustechtips.com/topic/780104-desk-pc-heat/#findComment-9835612
9 minutes ago, deXxterlab97 said:
Steel around the sides and glass on the top.
Ahhh, heat rising. Alright. I'll stick with a simple case. I just wish I could place it in a desk since I don't have a area in this room to place it properly. It just takes up unreasonable room. I can't particularly explain it.
Thanks anyway,
https://linustechtips.com/topic/780104-desk-pc-heat/#findComment-9835654
Thanks anyway,
Where do you live? What are ambient temps? How is the room?
https://linustechtips.com/topic/780104-desk-pc-heat/#findComment-9835733
England terrible usually cold when idle. Room gets hot when gaming for a long time though. My PC gives off a lot of heat when on full load and the walls are very insulating.
https://linustechtips.com/topic/780104-desk-pc-heat/#findComment-9852532
