Can you post pic of the case? Which GPU and CPU cooler you have?
The combinations which work best:
  1. If slot is over GPU and you have blower style GPU, intake
  2. If slot is over GPU and you have open-air style GPU, exhaust
  3. If slot is over CPU and you have stock or down-draft CPU cooler, intake
  4. If slot is over CPU and you have tower cooler, intake/exhaust (I haven't tested this one)
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/779997-case-fan-help/#findComment-9836508
