Cable help!
Go to solution Solved by RGProductions,
2 minutes ago, sivertholmvik said:
Hey, so i got a new headset and my computer only has a combo 3,5 port. My headset has two male 3,5. Does anybody know where to buy a adapter like that?
Thanks in advance?
https://www.amazon.com/ENVEL-Convertors-Smartphone-Microphone-Simultaneously/dp/B01M0T6PSF/ref=sr_1_6?ie=UTF8&qid=1494785007&sr=8-6&keywords=3.5mm+splitter+mic+and+audio
This?
What kind of port are you talking about when you say combo?
https://linustechtips.com/topic/779742-cable-help/#findComment-9831476
Thanks in advance?
This?
M1 MacBook Air 256/8 | iPhone 13 pro
https://linustechtips.com/topic/779742-cable-help/#findComment-9831478
https://linustechtips.com/topic/779742-cable-help/#findComment-9841368
