Help with insane ping
Solved by Master Disaster,
1 minute ago, DeezNoNos said:<a href="http://www.speedtest.net/my-result/6296847065"> <img src="http://www.speedtest.net/result/6296847065.png" /> </a>
Your connection is fine, you have 5ms ping to Google & 2ms ping to your closest Speed Test server.
If your having issues in game then it's a server issue, not your computer.
