Cable sleeving HELP!!
Go to solution Solved by whatthe_fuzz,
Lutro0's sleeving is your best bet. Not sure the gauge but I know for a fact its perfect for individual wires
Hello everyone,
I have an upcoming build (a couple of months - finally found a nice job to finance my project  :D ) and am set on sleeving my cables (PSU, SATA, etc.) but I came across an issue...
I have no idea what thickness sleeves to use, literally none.
I will be individually sleeving each cable, 24 pin, 8 pin, etc. for a Silverstone Strider Gold ST85FS-GS 850W (might change the wattage - still working on the logistics)
Any help will be awesome!
(I might do a build log, depends...like may be?)
i5 4670K | ASUS Z87 Gryphon | EVGA GTX 780 Classified | Kingston HyperX black 16GB |  Kingston HyperX 3K 120GB SSD | Seagate Barracude 3TB - RAID 1 | Silverstone Strider Plus 750W 80Plus Silver | CoolerMaster Hyper 212X | Fractal Design Define Mini
https://linustechtips.com/topic/77945-cable-sleeving-help/
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/77945-cable-sleeving-help/#findComment-1069828
just buy pre sleeved cables ;D bitfenix does some great ones
CPU 5900x| GPU 3080ti FE| MOBO MSI MPG CARBON MAX| RAM 32GB VENGENCE PRO 3200Mhz| STORAGE Samsung 980 Pro 1TB,2X WDSN750,4TB Seagate Barracuda| COOLING 1x Corsair 360mm XR7 54mm Radiator,1x EK-CoolStream PE 360mm Radiator| GPU Block: Corsair Hydro X Series, XG7 RGB| CPU Block: Corsair Hydro X Series, XC5 RGB| Fittings: EK-Torque STC & Corsair Hydro X Series XF| Pump/Res: EK-Quantum Kinetic TBE 300 D5| Tubing: Corsair Hydro X Series XT Softline| Liquid: Corsair Hydro X Series XL5 Clear| Fans: 10x Corsair SP120 RGB
https://linustechtips.com/topic/77945-cable-sleeving-help/#findComment-1069901
Not as fun as sleeving yourself. And when you sleeve yourself, you can go whatever color scheme you want.
NZXT Phantom windowed, Asus Z77 Sabertooth, Intel 2600K, Noctua NH-D14, EVGA 780 Classified, Crucial Ballistic Tactical, Crucial M4 128GB + Samsung 850 EVO, Corsair RM850, Creative X-Fi Fatal1ty Peripherals: Sennheiser HD598, FinalMouse Classic, SteelSeries Qck Heavy, Ducky Shine Zero (MX Brown), AOC G2460PF & Qnix QX2710
Build Log: Phantom - Antique Noctua
https://linustechtips.com/topic/77945-cable-sleeving-help/#findComment-1069940
hmm true ;D i might have to give it ago when I update my build next year January time
https://linustechtips.com/topic/77945-cable-sleeving-help/#findComment-1069983
Here is a comparison of your different options:
http://www.overclock.net/t/1443887/usb-and-psu-sleeving-review
ATX cables are best sleeved with around 4mm sleeving if that is any help :)
Current rig: i5 4670K | GTX 670 | Asus Z87I-Pro | Silverstone Strider Plus 600W | Custom mITX case | Seagate Barracuda 3TB | Samsung 840 120GB | G430 | CM Storm Quickfire Pro - MX Red | LG 21.5"
https://linustechtips.com/topic/77945-cable-sleeving-help/#findComment-1073063
